What are your impressions of the Alula?
Teach, the Alula stays in my truck at all times....can't think of better endorsement. I have thrown that thing till my arm falls off. I bought the basic airframe and added own electrics suite. Dsm-44 servos, built own niMH pack (1/3AA can be found at Batteries Plus) which gives me 720mah rather than stock 300. Servo throws are unbelievably small and excellent centering is a must. I am still tweaking mine, every time out I am adjusting this that or the other to get that much higher or hang that much longer. Love the challenge of squeezing every last bit of loft out of this thing. You will enjoy, especially if you have some slopes.What are your impressions of the Alula?
Wow thanks for link sir! I have looked at this product on AloftHobbies website, only sold in 18" pieces. I was looking into the CP laminate 5mil as possible hinge reinforcement and belly skid for few of my wings and bixler rather than bidirectional tape as I have been using. Had no clue there was supplier that close to my front door. Not sure that this is what I want on balsa build though, low shrink value scares me a bit. Being my first covering job I'm gonna need good shrink to hide some mistakes....course keeping in mind warping is an issue. This plane is small enough I would even consider fabric type iron on.....would also give me "that look" I am seeking. Whatever I go with it will have some transparency, balsa structure is just too darn pretty to cover all up.There is always DI Laminate sold at a company based in Irving, TX
http://www.laminatorwarehouse.com/laminating-film#72
but since I have not done balsa I do not know its strengths or weaknesses in this application. I do know however there are some who do use Laminate in lieu of any of the xxxkotes. I use a 3mm on foam wing builds and to strengthen balsa for control surfaces. You have to put it on carefully though because it doesn't shrink much at all.
Thurmond
