Mounting props on inverted motors
mzrhayes
Hi Guys! Finishing up my first quad build, its a v tail. My vtail has the rear motors facing downwards. My question is how do I install my props on these motor in order to push air towards the ground. I know they have to go label up. Should i use CW props on a CCW motor rotation and vice / versa. Will these props run effectively in reverse? this question has been messing with me for quite a while now!:confused:
Any advice is appreciated!
Mike...........
Mustang7302
The text on the prop will always face up to the sky when mounted. From there, just make sure the rotation of the motor has the leading edge of the prop biting into the air. The back right will spin CW (right) and the back left will spin CCW (left).
