MS Bf-110 build & plans
Whit Armstrong
Everything is labeled, and I just need to organize it all into sheets before releasing the plans!
Timmy
I've downloaded the plans from the resource section and ended up with this:
wut do i do?
The _MACOSX folder is empty
Edit: I've downloaded the plans from the post above and they're good.
Whit Armstrong
@Whit Armstrong would two motors each running a 6 or 7 inch prop work with this bird, or is it designed for something else?
Probably, It's supposed to have the same specs as the P-38. With a 6 or 7 in. prop, you would probably have to go with 4s, whereas as 9 or 10 inch prop could probably do 3s. Regardless, you have 12 inches to play with here.
