Wing connectors done and what a hassle, I was up till 1am last night !!!!
The wings can now be easily disconnected with two screws and one multiway connector.
Issues found...
- The three analogue servos for the gear doors do not play nicely with the other digital flight surface servos - replacement digital servos ordered!
- The sequencer for the landing gear and doors is not working for the front gear door (the sequence is wrong for that and it's not adjustable) - will use an FMS one for that - ordered!
Finalised the ESC location and made a small support for it so there will be no chance of it moving when glued in (that will be the last thing). Set up the ailerons and flaps, three rates for the ailerons and a motor cut. Also set the failsafe.
My soldering iron bit is knackered so I cannot finish the tail feather connections at this moment. Two 5000mAh 6S batteries ordered (ouch!) and still to find the 'perfect' pilot figure.
Here's a few piccys of the plane on it's mains - it's looking fantastic.
