My first 3D printed plane - Avro Vulcan
CarolineTyler
Aint that how it always works?? I need to replace the hotend temp sensor on mine. No strain relief, so unless I re-engineer the wire routing it will be a recurring problem.
In its life I've been through 3 hotends and about 7 nozzles, replaced the PSU, added MOSFETS for hotend and heated bed. Fiddling around with these printers is just expected :D
CarolineTyler
Weighing the plane so far it's 590gm minus the control surfaces.. should hit the recommended AUW within 2 or 3 %.
Excellent.....come on postie, I need my printer motherboard so I can finish this beautiful plane
quorneng
Caroline
I agree about needing 'DIY' on these 3D printers. Only had to replace the actual hot end heating element on mine in 4 years use but I have gone to some trouble to print clever flexible cable caterpillars (from Thingyverse) to avoid localised bending stress points on the cable runs.
550 g sounds reasonable. What is the expected all up ready to go?
CarolineTyler
Caroline
Around 800gm airframe with EDF and all other electronics, with battery you're looking at 940 - 980gm
CarolineTyler
All the parts so far, the vertical stabiliser and tail dome have been joined properly.
I want to re-print the middle section of the fuselage as it has some parts that I'm sure I can do better with.
Medium-small banana for scale...
I have upgraded hot-ends, extruders, tensioners, fans, bed tape, etc... or a combination of them on all my printers. They all seem to have at least two weaknesses in design. Gives me more opportunity to fiddle. LOL!
quorneng
Vary nice.
I am not sure I need to know why you chose a banana, not the most obvious distance measuring article. ;)
A 24" steel rule is my 'go to'.
CarolineTyler
Just fixed the 3D printer - the new motherboard arrived at lunchtime but it was loaded with ANET E16 firmware. Queue lots of how to load firmware on an ANET motherboard google searches and youtube videos. Decided to go with Marlin 1.1.9. as it includes safety code to stop thermal runaways. Long and the short of it is that it's running.
50mm EDF arrived today as well and I've fitted it into the EDF printed housing, this is so well designed it fitted perfectly.
Ordered some plastic putty so I can fill minor surface artifacts you sometimes get when printing one layer thick skins.
I'm getting excited !!!!
CarolineTyler
Central fuselage is together, EDF in place, ESC connected and spinning in the right way :)
The red strings are for pulling the servo leads through.
3D printer is still playing up, after printing the centre section of the fuselage fine it's started complaining about hotend temperatures being wrong. Looks like I will have to replace the thermistor. With all the reprints I'm almost out of filament, so another reel ordered from Amazon basics.
IMG_20210408_214635093.jpg IMG_20210408_214705868.jpg IMG_20210408_214648064.jpg
EDF pulls 36 amps on 3S, this unit is not rated for 4S as it's 5400kv
The Fopster
Thank you, it's a terrific 3D model and I'm glad all this thin walled printing worked, it took quite a while for me to delve down the Cura rabbit hole.
Just hope it flies!!!! ;)
I may ask to steal your gcodes if I make one. I'm not doing very well with Cura so far. 😕
