My First Balsa Build - Willy Nillies, Ace GLH 250 - "What have I done?!" = Balsa Build Along 2019-2020
kilroy07
So, I have to admit, I was a little apprehensive about getting into Balsa.
Mainly due to the "stigma" from the local club members (aka old fogeys) when I show up with my latest foamboard creation....
That aside, I've been a hobbyist for as long as I can remember and I always thought "I can do that"... I just don't want to invest a year's worth of time in something that might shatter on the first flight. I "might" have been traumatized as a kid from spending a lot of hard earned money and time on a Guillow's kit, only to watch it shatter....) I still shudder to this day when I see the box with the Tempest picture on it... :LOL::oops::cry:
Along comes the Balsa Build along...
https://forum.flitetest.com/index.php?threads/balsa-build-along-for-2019-2020.60671/
Finally, experienced builders who want to share and help rather than snear and criticize... Thank you SO much @rockyboy, @willsonman and the others!
For not only sharing your knowledge but taking us noobs under their wing!
So alright, here it is. Awhile ago I ordered the Ace GLH 250. Have to admit, I had a hard time choosing.
I really liked the Eaglet, Barnstomer and who doesn't love the Cub?!
I'm finally (FINALLY) done with a hectic work schedule this year so I figured why not?! It's not like I have like twenty other projects going on (I do!)...
Anyway here we go!
kilroy07
So this arrived while I was on the road.
The unboxing;
IMG_0044.JPG I have some yellow covering on hand. The plan is to make it a two tone yellow/green scheme with the checker being a stripe on the left wing (for orientation.)
I also picked up a motor and servos from W.N. as I really didn't have anything in that size category. I am a tad apprehensive about the size, as I have found that bigger planes just fly better....
First thing I noticed tonight was the retaining clip on the motor shaft was a tad bigger than the hole in the motor mount.
IMG_0045.JPG I used a 1/4" drill bit to widen the hole. I had a piece chip out from the side, but I think it will be okay... (should have soaked it in super glue before drilling.)
Looks like they W.N. have updated the kit with blind nuts... Awesome!!
IMG_0046.JPG Really like this idea, though if I do have to replace the motor, running the wires will be a pain...
I'm really "getting attached" to this plane now!
The motor tray needed to trimmed just a bit to make room for the blind nuts (explained in the video....
Which reminds me... The only downside to the kit so far is that my instructions were only one sided, and didn't actually include any "instructions" just the cover sheet and the end "set up to fly" section!... :oops::LOL:
IMG_0056.JPG Fortunately there are links to both the PDF instructions and the build video(s) on their website.
So tonight I've gotten to the point where I need to do some soldering and figure out my plan for electronics...
A good place to stop for the night.
Well... Okay, maybe a touch of sanding "Just to see how it will turn out."
While it "could" use a touch of filler and re-sanding, this is my first balsa build and I'd better leave some room for improvement! :LOL:
kilroy07
GLH is a fun build and flies great. There are several build threads here already so take a look at them if you need any help or inspiration.
The only part I think might give me trouble is setting up the servos/control linkages.
How the sheeting in the wings and when is the best time to do like control horns (before or after covering) is what still mystifies me.
(the 3 build videos are great for what they cover, but there is a lot between where they stop and flying begins...) ;)
rockyboy
Skill Collector
Looking good! :D
Best time to do the control horns is definitely after the covering is on. They are a pain to try to work around. In fact, any pieces (tail & wing) you can leave separate to cover while flat is usually best - then it's just a matter of cutting away enough covering so you get a good balsa to balsa glue connection to put the parts together.
I haven't done this build yet so I'm not sure about the wing sheeting mystery - hopefully someone who has done this part will chime in soon!
TooJung2Die
Wow, I can relate to that. I dreamed of flying an RC airplane when I was a boy but could only afford Guillow's free-flight kits. Most of which never flew that great. Fast forward 40 plus years. After a few years of building, flying and crashing foam board airplanes I got good enough that I usually came home with all my airplanes intact. Last year I built my first balsa airplane in over 45 years and there's no looking back!
These Willy Nillie kits build a lot easier and faster than the old die-cut balsa kits. The laser cut parts make it so easy it's almost like cheating. I'll be watching your GLH go together.
PS - Does anyone remember the first GLH? Carroll Shelby designed the Omni GLH for Dodge back in the eighties; a four cylinder turbo Mustang eater. They named it GLH for "Goes Like Hell".
kilroy07
So I just tripped over your construction guide... Man, I CANNOT thank you enough!!!
SO many small nagging questions I had are all answered now... (I think!) :ROFLMAO:
Well done man! (y)(y)
For others who are building the GLH (or probably any other Willy Nillies kit) I seriously recommend you check out the PDF build guide!
https://forum.flitetest.com/index.php?threads/willy-nillies-glh-250-assembly-guide.60522/
Turbojoe
I always cover making sure the area immediately around the control horn slots is VERY firmly attached. I then use a low watt pencil soldering iron with the smallest possible tip to easily open the slots for the horns. It also works exceptionally well for opening screw holes in covering. An Xacto knife will work fine but I always have a soldering iron(s) on the bench and just got used to using the soldering iron method.
I'm starting to think this little GLH might be my 3rd Willy Nillies kit.
Joe
vhandon
Like everyone on here, I just want to contribute in some way. Glad you found something useful in it.
kilroy07
could I ask a favor?
I have a plan for my electronics, but would like to see how others did their servos, receiver and ESC (location, mounting methods etc.)
A quick pic would be great!!
Thanks in advance!
Willy Nillies
We will get your more photos tomorrow.
Sincerely,
Doug and Becky
WillyNillies.com
kilroy07
Another day of building and another day of errors... :rolleyes:
These came in the mail today so I can finalize my ideas on electronics.
This was my first mistake... Doh!
There were others again dealing with this part...
I sanded the ends to match the leading edge... turns out the flat matches the back of the hatch.... :oops:
So, there will be a gap on mine.... (Oh well, that'll be one thing I can improve upon next time.)
I also forgot rib 2A on the first wing.... That was a pain to put in later! :mad:
I did have some issue with getting the servos to fit... and I'm not sure if that's just by design.
Not sure if putting the servo seated before gluing in the doubler (Rib 2A) would have helped that or not...
More often than not I'm pretty sure most (all) of the issues today were with me...
LOTs of "distractions" and my head was elsewhere...
here's where I stopped for the night though.
Got pretty far.
Weather looks to be good Thursday/Friday... hoping to have three new planes to maiden!!!!
OliverW
Got pretty far.
Looking good!
kilroy07
Got some time to work last night.
Except for the ailerons I think I'm ready to cover.
I revisited my error with encouragement from @Joker 53150 to fix the tapered leading edge of the wing.
Then realized the hatch has a lip anyway... Oh well...
Speaking of the hatch, I decided to magnetize it.
Tail surfaces are all shaped and ready to cover.
The fit for the Horizontal stabilizer was pretty tight, slight crack towards the very front of the slot... But I think it will be fine.
