hellogoose
My guess is you may find it hard to get down to sub 250g using the material, motor and servos of your first plane unless you use a
very small battery too.
I have built several 'own design' power sub 250g RC foam board planes as well as converted two solid foam chuck gliders to sub 250g power RC.
Something like this but not with the "over the top" true scale features I incorporated.
40" span and sub 250g ready to go it still flies very nicely.
You will quickly find that keeping to a reasonable size
and keeping to 250g are conflicting targets. Big(ish)
and light is hard to do!
My suggestion is to build a reasonable sized plane, say with at least a 1m (40") span and get it (and you) to fly it well. At this point you will have a plane of a flyable configuration, only then set about the problem of how to make it lighter (it could need as much as a 40% reduction!) and still be practical flyable plane.
If your
first build is a very light plane and it doesn't fly properly you won't know if its due to its design, the execution of the build or your flying skills!
Just get to where you want to go using modest logical steps.
I hope this helps.
