meowmixdelivers
Today my knuckle quad fought with a tree and lost. :( I found the poor creature on the ground missing a leg and propeller.
I took it back home, fixed it up, and tested it out. One of the motors started spinning later than the others and stopped spinning earlier. I unplugged the battery and spun each motor by hand. When I turned the working motors, they seemed normal, but the motor that started later has a spot where it seems to stick a little bit. I looked at the shaft coming out of the bottom of the motor, and it seems straight. The quad flies normally too.
Should I be ordering another motor? Is there a way to repair this sticky one? I really dislike the idea of ordering just one motor from hobbyking and paying all that shipping! It is this one by the way: :mad:http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=18150
xuzme720
Dedicated foam bender
Pull it apart and see if you can find the sticky. It could be as simple as something like debris in the can or a bent shaft or damaged bearing inside.
Also, please warn your models about the dangers of the killer trees!
cranialrectosis
I'd order two motors and spare whatnot today.
Then pull the motor apart and look for debris etc like Xuzme said.
Friggin' copter eating trees.... :(
meowmixdelivers
Update:
I performed surgery on my flying friend, taking off the affected motor and pulling it apart (damn that little black clip). The shaft did not seem to be bent. I did see this weird black plastic mass (tumor?) near where the wires entered the motor (I should've taken pictures). I assume it is supposed to be there, but it was partially in front of one of the copper coils. So I mashed it down with a screw driver. After putting the motor back on, and the prop back on the motor, I tested it out with the other motors. It starts at the same time as the others now, and ends at the same time as well when throttle is cut on a flat surface.
This has been a good experience in motor surgery. I learned how to take apart a motor.
@xuzme720
I have gave my quad a gentle scolding after it had some time to recover from the operation. It says that it will stay away from trees from now on.
@cranialrectosis
I will still be ordering some spare motors and motor parts because there are still telephone poles, buildings, and the ground to run into.
adamd
skunkworx hobbies
for the hobbyking i usually wait until i have a bunch of stuff i need then make an order or even split it with friends.
to be honest i usually only need i 1 thing then fill my cart with useless stuff like more motors, esc, props, and random battery so i can get fedex shipping :p
