Whats up FliteTest community...
So after doing a ton of research I finally pulled the trigger and placed an order for a bunch of FPV gear. This is my first FPV setup ever. Even though I am not new to the world of RC I am new to FPV.
Like I mentioned above I did a ton of research and I am fairly confident that the gear I purchased should work for me but I thought I would list everything I ordered so you guys can look it over and post opinions, advise, give reviews of the gear if you own it and most importantly let me know if I forgot anything or if I messed up and ordered the wrong stuff.
I decided to go with Foxtech instead of Fatshark because my research indicated that the Skyzone goggles come with more features right out of the box with no need to purchase extra "modules". Like built in diversity (no need for a separate ground station) and head tracking. I also decided to get the CYCLOPS BREEZE PRO OSD even though my research indicated it is not the best choice for multi rotors but it is cheap and a lot of people are using it on multi rotors successfully. (opinions???)
Gear I already own and plan to fly FPV with:
DJI F550 with the Naza M V2 +GPS
GoPro Hero3+ Black
DJI Zenmuse H3 2D gimbal
Spektrum DX8 with the Spektrum AR8000 receiver, including telemetry module
I also plan on flying FPV with my FliteTest Versa Wing
The new gear I ordered:
1- SKYZONE FPV Goggles
2- CYCLOPS BREEZE PRO OSD
3- Foxtech TS800 32CH 1.5W VTX(Remote CH/Freq. Select)
4- Foxtech 5.8G TX/RX Cloverleaf antenna(SMA, inner pin)
5- Wireless 8CH 5.8G DVR-DV01
6- Foxtech 5.8G 12dbi Helical Antenna(Left/SMA) for Receiver
7- Plastic pan/tilt for 9g servos
8- 160degree metal gear servo
9- FH32-700 700tvl camera with OSD function(NTSC)
Thanks Guys!
fretsman
GoPro Hero3+ Black
Thanks Guys!
fretsman
