eagle4
I'm still yet to purchase my first piece of FPV equiptment, and was just after some advice.
I'm curious what your thoughts are on the Fatshark Predator V2 goggles were? I see I can get them online with the whole kit and kaboodle for about $280. That's camera and everything. is this a good deal? I guess the FatShark transporter V3 is designed for people to basically upgrade straight away, but i wonder about the predators. I know that I'll probably need to upgrade to a cloverleaf antenna straight away, but would this be good enough to get into the hobby? is there a problem going with the predators rather than the dominators, as i've heard you can change the reciever module in the dominators, which means you're not tied into the fatshark system incase another brand has other stuff you want to use. What are your thoughts on this?
Also it seems that almost everyone is out of stock on anything fatshark, I have however found these guys. http://hobbywireless.com/ are they any good? anyone had problems with these guys? Can you recommend someone else (who has stock).
Is it customary to get the transmitter away from things like the esc? or is it better to keep the transmitter close, but have the aerial on a long extension to get it away from all the other wiring?
In the attitude goggles, i see that you can adjust the distance between your eyes, ipd adjustment, is this a big deal? i dont think my face is too abnormal, but not sure how bad this could be if you're slightly off.
and any other advice for a super beginner would be truly appreciated.
Dave
Dave
