Hi,
I recently got a DX6i tx and planed to build an plane, I built an ft flyer from 6mm extruded polystiren with an 1450kv motor and 2s 900mah battery.
learning to fly it was hard for me and painful for the plane but it finally flies and I can keep it in the air.
The first try I crashed the plane and bent it really bad, and I made another one
The problem is both planes when I don`t pull up they start diving and tilt to the left, I checked the cg to be as marked but sill same problem, should I move the cg more to the back ?
I also made an ft delta but with the same motor and battery it is way to heavy, it falls like a rock, I placed the battery in line with the elevons to have the correct cg.
thank you.
regards,
Cosmin
thank you.
regards,
Cosmin
