mrjdstewart
and no, the 2208 is for the cub. way to big for a mini. i can toss in a a-pack motor into the box as well for you.
me
me
nice. I have a box of stuff for you as well. I have also built probably 10 diff cubs by this point as well. let me know if you need any help.
our club winter party is the 15th. you should really try and make it. it would be a good day to meet and intro you to everyone. I can also bring a buddy box and let you fly my radian glider. everyone should start with a glider in my opinion.
let me know how i can help.
me
and no, the 2208 is for the cub. way too big for a mini. I can toss in a a-pack motor into the box as well for you.
me
Oh, you are definitely thinking it out, doing the math and working through the issues. You have obviously done your homework. I've never been good at math.
A thought though? If you're good at math, figure out what your detailing might weigh, where it's going to be and then just put weights there and figure the flight characteristics out. Then you can build your thing and the balancing would be pretty close to where it ought to be.
I've been looking for a different Cub to build and I think this one is it!!Here is a Cub (Thanks Shaun Martin) that I built with this method.
I thought that about 3° was normal-ish. Just looking at it, it does not look like 6° to me. Were talking about the modified (blue) TT fuselage, right?I would say that 6 deg incidence on the wing is way to much. I'd use 2 deg on a plane like that plus at least 3 deg downthrust on the motor. I reckon that if you try and fly that plane with zero downthrust and 6 deg of incidence, it'll fly around with its nose in the air and waggling its tail like an eel, and whenever you open the throttle, it'll go vertical or try to loop. You might be able to keep it in the air if there's no wind.
I don't like to discourage anybody from trying anything. At least we learn what happens, but if you want it to fly nicely, you need to stick with established design principles.
Ahh... High wing, floaty bush plane with tundra wheels...neutral down thrust?
Looks like you've got it. As long as you understand those basic principles, you'll be in the right ball park, but as HL says, you'll see whether you got it right when you do the first flight. With an understanding of what's going on, you can make the right adjustment if necessary.Ahh... Thanks for the explanation. Makes sense. Because the wing is mounted so close to the thrust line on the TT (and even the Bloody Baron/others) then there is little need for down thrust. Higher wing planes will need more down thrust...as a general rule.
So, if it were a Spitfire or the like with a low wing design, the down thrust is inherent in the design. Just a little right thrust is needed...maybe.
@PoorManRC
Instead of bevel cutting the edges to round them (which will weaken them and allow the paper to peel)
Gazoo
If only it was so simple!
There are other things to consider. Firstly if the motor is mounted below the planes centre of mass there will be a tendency for the plane to pull its nose up when full throttle is applied. In this situation ideally the thrust line should be such that it passes through the centre of mass for neutral behavior.
Second thing to consider is that If the motor is mounted quite low in the plane the aerodynamic drag can "pull" against the upper portion of the plane, (mostly on high wing, Parasol, and Biplane installations), this drag with the motor producing significant thrust can again cause a tendency to nose up further as the plane speed increases.
Have fun!
In all honestly no one will know exactly as your build has varied from the standard build BUT as an estimate it will be a good starting point!I definitely understand that! Is 2 degrees of down Thrust going to be enough?
Have fun!
