My First Tricopter/Multicopter Build
nishaad
Hello all, so this was my first ever experiment into the multirotor world!
I chose to build a tri because I like the way they look, and their unique flying abilities! Not as robotic as a quad, and almost natural and fluid like! Inspiration was taken from rcexplorer.se, Cheers David! and the Aeroquad forums
So here are some photos of my build... Once I get used to flying it well I will sort out a video!
The downpipe clamp landing gear was too bouncy, so I had some landing gear 3d printed!
I also had the little velcro strap that held the battery tear off in flight! which ended badly... and so i built this! Again inspiration was taken from David from Rcexplorer and his design.
nishaad
Good looking tri :) whats the control board you built up based on?
I used a arduino based flight controller. Its an arduino Mega with the sheild bought from Aeroquad, containing gyros, accelerometers, a magnetometer and a barometer. The code used to fly it is also from aeroquad.
The reason i went down that route, is because this year, I will be trying to use optical flow to make the tri autonomously follow an object! and an Arduino mega should give me enough flexibility to do just that. A Raspberry Pi will be used to do most of the image processing onboard.
Looks great. And putting the motor inboard of the servo is a nice twist on RcExplorer's design.
Haha yes, well it was more a necessity, I needed this in the air asap, and I didnt want to fluff around with the code too much. The servo was compensating in the wrong direction, so instead of using code to fix it, i just used a simpler mechanical solution - turn the whole thing around!
nishaad
Here was the first flight that was caught on video! its from last year... so features the older landing gear etc.
nishaad
looking good :)
Cheers Black Knight! but sadly its grounded till I get a replacement tail servo. I managed to strip the metal gears and hence need to wait while hobbyking restocks the servo I used... Pain really, but such is life. Its currently a stormy winter, so the wait isnt so bad.
