Solved My T-28 can't fly in a straight line!
short_nathan
I have an E-Flite T-28 1.1m that for some reason can't fly in a Straight line, and flying it is super annoying. I tried solving it by centering the control surfaces but it still doesn't wnat to fly in a staright line.
short_nathan
Well, about that....I haven't EVER been succesful with trimming mid-air. I am new in the trimming stuff, but each time I have tried to trim that plane, it just becomes worse.
bisco
so if it is turning right, you would want some extra left rudder, and vice versa.
ailerons can make it turn as well.
does it fly staight with 'safe' on?
...I haven't EVER been succesful with trimming mid-air. I am new in the trimming stuff...
Trimming, while flying, is a skill you must learn. It's easy once you know how. All planes that are out of trim are difficult to fly.
Think about what stick inputs you are giving it to make it fly straight. Then move the trim tabs the same direction.
Example: If the plane climbs, you will need to input down elevator (push forward on the elevator) to make it fly straight. To trim the elevator, push forward on the trim tab. Keep adding elevator trim until the plane no longer climds. All of the other axis are the same, what ever direction you push the stick to correct, push the trim tabs that same direction until the plane flies straight.
Every plane I have ever owned has needed some trim. I trim some of my planes every time I fly them, not by much, but still a click or two.
Bricks
After repair did you check CG and balance from right and left after repair may have one wing heavier then the other ?
When applying trim do a little at a time, make adjustment sticks neutral let plane fly no input no throttle change, still not right apply more, it may take multiple trims to different surfaces.
L Edge
You said that you broke the wing off, assumed you glued it back on. Could be there is a difference in the angles of each wing, perhaps a twist even?
short_nathan
It didn't notice much difference, but I will check.........I just checked and one wing is pointing upwards a little bit more than the other one.
bisco
it's worth a try. if you struggle finding the trim tabs, see if someone can do it for you while you fly the plane
