Javiester
I have found a way to print the plans that I find more comfortable for not having to work with a large plane formed of many sheets
I download the full map and open it with the Inkscape , selecting the page you want to do first
Then I select everything we don't need and delete it
I select everything in the menu or with the mouse and ungroup from the object menu
sometimes you have to give it a couple of times until it looks like in the picture
Now I select each of the largest parts of a sheet and group them into individual pieces by saving them in different files
and the small ones in A4 or letter sheets
I'm going to take the fuselage
Now I open the file that I saved as fuselage
I save it as a pdf but I select the option of the object size and not the paper size
when you open it with the pdf reader it will look like this
