Pieliker96
The NASA Ames-Dryden 1 is a fairly wack exercise in variable geometry. The real thing was limited to relatively low speeds due to aeroelastic concerns, in addition to the fact that it had been built on a shoestring budget of $240K. I've built the wing and associated actuator rather stout to counter the aeroelasticity - though, in the spirit of the real thing, most of what I'll be building it with is already available to me - I'll only be buying the EDFs and ESCs new.
Here's some pictures of the build process:
Wing going together. Note the main spar (0.25" x 0.75" birch ply) and mounting plate.
Here's the actuator, it's the same I used in the B1-B project - the Actuonix L12-R in the 100mm stroke variety. Actuation speed is rather low but isn't critical in this application.
Some pics of the glue-up of and of the completed wing pivot mechanism. It's constructed of 1/8" plywood and rides on a 1/4" diameter zinc-plated jesus bolt with a nylock nut. Total actuation range is 0 - 65° - the real thing did 0-60°, I wanted a little extra to make storage easier. It was built to the highest engineering standards of "looks strong enough, she'll be aight".
Tail assembly, empennage, and main gear. I used ES09MDs for all control surfaces along with a 10A BEC for flight control. The main gear slots into the fuselage in the traditional FT style, the fuselage is almost entirely monocoque with a good bit of paper removed to save weight.
Installed wing actuator and completed fuselage. The space behind the cockpit will serve as the battery hatch, the tray for which I have yet to make. The nose wheel is steerable and tied to the rudder channel by means of a 5g micro servo with a slot in its control arm.
Aircraft sans motor pods, EDFs, and ESCs. Wingspan (unswept) is 67". With a projected all-up weight of 1400g, Cube loading is around 9. I'm planning on using twin 50mm EDFs on 4S, which will be installed a few months from now (college being what it is). That'll give it a thrust-to-weight of around 0.8, as opposed to the real thing's abysmal TWR of 0.21 - it's easier to get away with low TWRs with highly efficient wings and miles of runway, a luxury scarce in the hobby world.
One of the interesting consequences of the oblique wing is a coupling between roll and pitch control: Applying roll deflects the ailerons in opposite directions, which, since one is aft of and one is fore of the CG, pitches the craft up or down. I've added a couple of mixes to counter this effect. In the real thing, pilots reported the coupling was manageable under 45° but became more of a nuisance as sweep approached 60°, during which the aeroelastic effects became more pronounced. There is a significant, higher-than-usual chance of this thing breaking up in-flight due to aeroelasticity and/or flutter of sorts. The easiest way to find out is to just go and fly it!
Maiden Flight NET May 2021.
