Jahnkeanater
Here is a Naze setup that I would like to show every one. Its a flip32+ with Bluetooth and a Spektrum satellite receiver. Some things to note are that the flip32 stock does not work with the satellite plug. You have to fix the board or use a special plug. This fix uses the gps rx pin so if you want to add gps you may have to hook it up differently or use a ppm converter instead. Also the Bluetooth pins are not in the same order on the board you have to swap VCC and ground as well as rxd and txd. Make sure rxd goes to txd and vice verse. In order to activate the satellite receiver you have to set UART2 to Serial RX in the ports tab and change the receiver mode to RX_SERIAL in the configuration tab. dsm2 is 1024 and dsmX can be either 2048/1024 depending on how you bind it. I recommend using an official Spectrum DSMX Rx to bind your satellite receiver.
