Bleumunkie
Originally posted in FPV, but since the problem is not specific to FPV, but the Naze32 - I figured it could go here too..
If I broke a rule, let me know and I'll delete, just trying to get help as soon as I can.
I have built a BNV for FPV flight. Plan was to use a Naze32 for flight stabilization and OSD support. Maybe RTH if the firmware ever improves, but that is outside this post.
Here is the problem:
If i test the ailerons they respond normally - quick and to the extent of their travel, returning to neutral when the stick is released. However - If I have the throttle anywhere above 0, my left aileron will start dropping even though it is just sitting on my table. The ailerons react to the right stick being moved, but stick out of neutral spot when the stick is released. Dropping the throttle back to zero immediatly brings the ailerons back to neutral (as if they where out of place and you plugged in a battery).
If i put the Naze32 in passthru mode, I get about 1/2 the travel and slightly slower response, but it is otherwise unaffected by throttle position.
Video attached demonstrating problem. Please help!!!
Stats:
BNV completely to spec - built out of corrugated plastic
Naze32 Acro rev 5 w/ Cleanflight.
..... turning the board 90 degrees for wiring convenience.
..... Aux 1 arms the board
..... Aux 2 handles switching between passthru / acro / horizon modes.
any other questions I will answer, but unaware of any other factors ahead of time.
Stats:
