Naze32 Lemon dsmx rx & clean flight not binding.
DoctorDuke
Crash Test Pilot
I'm about ready to sell my spectrum stuff and start with Taranis like every other quad guy.
But maybe someone here can save me...
So here is the deal.
I've tried this with the Lemon dsmx wired to the three spectrum ports of the naze32 rev6 board and the 3v /grd and port 4 option.
Open Clean Flight
Plug in usb
Lemon lights up briefly
In the ports tab, choose UART2 : RX = Serial RX (save)
In the Configuration tab Reciever mode: RX_SERIAL and Serial Reciever Provider: SPEKTRM2048 (save)
In the CLI tab type: "set spektrum_sat_bind = 9" sype "save" reboot
unplug usb and wait a bit plug usb in and nothing (besides breif light on power)
Back in Clean Flight
Ports and Configuration Tab look good
Now, going through and checking settings manually in CLI tab and "dump" shows "set spektrum_sat_bind = 0 "
re-enter " set spektrum_sat_bind = 9 " and "save"
wait for reboot and "dump" - now shows "set spektrum_sat_bind = 9"
Unplug usb, plug usb back in - and "dump" shows " set spektrum_sat_bind = 0 "
So it looks like the spektrum_sat_bind setting isn't staying after disconnecting from the usb for whatever reason and probably the resason why the rx is not going into bind mode.
Any thoughts?
Craftydan
Hostage Taker of Quads
Doc,
The sat bind function is a single-shot operation run at cold boot.
You could set/save the spektrum_sat_bind variable then warm boot the Naze dozens of times and the value will stick, but that's because the bind-mode code would also never execute. Power down to start a cold boot, and the bind code runs. As it finishes, it resets the variable back to 0 (you don't want to enter bind mode every time you power up, after all -- this isn't a Hubsan quad ;) ).
The fact that yours is resetting to "0" is a positive thing. The board is trying . . . but the LemonRX just ain't getting it. Go back and double check your port assignments, double check your wiring, try other spektrum_sat_bind values (try 5, 7, and 8 as well), and if you've got a satellite capable receiver, plug it into that and check to see if it can power up and bind (there's always a chance the RX is *ahem* a lemon).
DoctorDuke
Crash Test Pilot
Thanks for the input, but after some more searching it looks like the spektrum binding just doesn't work on the naze32 v6 board.
https://github.com/cleanflight/cleanflight/issues/1321
" Attention Spektrum satellite users - satellite binding is not currently working with Rev 6 hardware - you must bind your satellite with separately with a receiver before connecting to the Naze board"
"Spektrum sat binding doesnt seem possible on the rev6 without a hardware modification. This is due to the included SBUS inverter which only allows signal going in and not out (the spektrum port signal trace shouldve bypassed the inverter imo).
This means firmware wont fix this unless the sat is connected to another gpio just for binding, and then reconnected to the uart2 port. Or you could desolder the SBUS inverter and jump the pins like I did (marked in the image below).
Sorry if this seems off topic, but it didn't seem clear that this was a hardware issue rather than firmware when it was previously mentioned. "
I actually don't have a receiver handy with a satellite port, so I'll oder one up or maybe try the desodler and jump mod above
damouav
Spectrum sats dont bind on rev6 Naze32, correct. But if you bind the sat to a full rx first then wire it up it dose. I had the same issue when setting up my Naze32.
I too have gotten to the point where my current Spectrum gear is about to be moth balled for a new Taranis rig.
All the best of luck.
If you need any further assistance with your LemonRX gear look up the RCG which has extensive information which maybe useful.
DoctorDuke
Crash Test Pilot
Thanks... Seems a pretty big shame it took so much digging and research to figure it out. Ordered another rx just so I can bind it and be done, but what are you going to do? Wish I had the foresight when getting into fixed wings about the spektrum gear - ohwell. I might just keep it for the plans and go taranis for multi rotors.
What is the RCG? Google didn't quite help me out with that one.
damouav
Yes, I know what you mean about the radio gear. Live and learn I suppose.
The forum on RCG is Lemon DSM2/DSMX Compatible Receivers (http://www.rcgroups.com/forums/showthread.php?t=1773138).
Just make sure when binding the sat with the full rx that you cycle the power (off/on) several times so your 100% sure its bound correctly. This maybe a problem with my old DX7 DSM2 gear, or maybe just spectrum gear in general.
