austingillis85
Ok guys I'm new here but been doing multi rotors for a while now.
I decided to go from a naza lite to a naze32 acro. I got everything soldered and did the basic setup like on these guys video and most on youtube.
For the lift of me I can't figure out whats going on.
Even in rate mode (nothing selected) it freaks out. I've attached a link to show you. It will fight everything I do even if its pretty close to level. If its off level it try's to flip over and over with random motors.
If I go to angle (which I do half way through the video) it try's to just keep flipping with one motor at a time.
I've re calibrated the ESC's multiple times, calibrated the accelerometer multiple times and reset to defaults. From what I can see on the sticks its good. I've also looks at rotation and motor placement about a million times.
I've also tried baseflight and cleanflight both with the same issue. Could it be a bad motor?
So at first I un arm. Pull throttle up about 20% in rate mode. Middle of the video I go into angle with the same issue.
I'm at my wits end guys any suggestions?
