Multipath interference is caused by signals bouncing off of reflective objects like walls, and arriving at the Rx at different times. Circular polarization (CP) removes quite a lot of that, but in open areas you won't notice a difference. If you are using a CP Rx antenna, you actually will see a bit of range increase by moving to a CP Tx antenna, just make sure they match right hand or left hand.
