Need advice with the corsair build!
Flightman
I am attaching the cowl with the pod holder into the main fuselage, how far down the does cowling go onto the E former? Should bottom lip of the pod holder be flush with the E former or do I push it down as far as it will go when gluing it?
mrjdstewart
the pod holder should sit flush with the front of the cowling. you then add a bead of glue to the front to seal it all in.
hope this helps. if you need more pics let me know.
me :cool:
Flightman
me :cool:
I meant about the connection between the cowling and the fuselage, I just assumed the pod was going to sit flush inside right?
mrjdstewart
the front cowl sits all the way down to the line. it takes a little work. sorry if i' m not understanding. hope this helps...
