Need help bloody baron first time set up
Jgreg
What is your settings expo , gain’s anything you can think of for novice bloody baron set up novice RC skilled pilot
What is your settings expo...
Once you get a little experience with it, do what Bricks said, max it out!!
To start with, I'd use the throws for low rate as indicated on the plans. Expo is totally personal choice, some like little to none, others like a lot. I like about 30-40% expo myself. You might try 20% expo to start with, if you like it try a bit more.
Jgreg
I have both new builds with me. I don’t have the plans or any info . Please let me know what was on the plans thanks in advance ! Also any links that you have on new videos etc , please send!
AIRFORGE
Make It Fly!
The plans are attached.
Throw Guage is LOW 12 degrees, HIGH 20 degrees. You'll see it on the first sheet of parts in the plans.
I'd adjust throws to 20 (or more) and set low/high rates to a switch. That way you can fly tame or flame!
  • FT_Bloody_Baron_v1.1_Full-Size.pdf
They are neutrally stable* upright, kinda suck inverted because of wing profile, but do sucessfully fly inverted or at least my C pack powered one does.
They ARE responsive to control input. Lots of expo on first flights
*Neutrally stable: put it in a turn and it continues that turn until some force disturbs the flight.
Bricks
Yes Sir ground, trees, fences, other planes, buildings are all disrupters just mentioned a few . :)(y)
You neglected the loose nut on the control stick. Has caused numerous unexplained demise events
