Need Help - HK Quad Copter Programer.
I have the KKMulticopter USB Programmer and I have everything recognized, but I need to change it from Plus Mode to "X" Mode. How do we do that? Any advice would be appreaciated.
ananas1301
Crazy flyer/crasher :D
#2
hey John,
I´d recommend you have a little closer look at this page. It explains practically everything very easy and tutorial like so you shouldn´t have problems following that :D
http://rcexplorer.se/Educational/HKKK/HKKK.html
Even with other control boards it is the same procedure. The only thing that is changing then is the controller you choose in the programm to reflash and I have not seen a KK board not being able to be reflashed so you should find yours there too :)
Hope I could help you here.
#3
I now have it setup to where I can get to the X firmware. I choose it and then I get the following (See Image)
Error during setting the fuses
Flashing of Firmware Aborted.
#4
Doing some research, it appears that it may not be seeing my programmer, but the computer is seeing it. What programmer do you use for the HK programmer.
#5
My bust.... Software did not load correctly for the driver. Had to load the driver manually, even though it said it loaded correctly.
#7
Is it working now then!?
Yes, worked very well... The directions show where to plug in the motors for "+" configuration, guess I will have to experiment (Without Props) as to what motors get plugged into what. I am guessing motor 1 is to the left of the direction of flight, but not 100% sure. Thanks for the assist.
Tritium
Amateur Extra Class K5TWM
#8
John, I am just finishing up a micro quad and have a few questions. Did you discover the motor numbering for X configuration and what software image did you use? Also what direction does each numbered motor rotate and can they be reversed in software?
Thurmond
