The drawn amps is more than anything else depending on your flying style.
Unless - you are flying pylon with 100% throttle at all time.
For my own flying i am calculating with 30-50% of maximum power in normal weather depending on plane.
I can calculate down to 15-20% on a motor glider.
I will need a lot more when the weather is bad - like this passed days with 10 m/s average winds - (36 kph, 22 mph).
The maximum power is best known from tests you can read for your motor and propeller on the net.
Example : 10 Amps and a battery of 1000 mAh will give in theory 1/10 hour = 6 minutes.
You will normally not go under 80 % giving you more like 4-5 minutes flight at full power and 2 to 3 times that on cruising.
