Need help KISS FC Airmode
Bromego
I have my min throttle set to 1060 and and min command set to 1000 per what I have been reading online, but when I chop the throttle my quad falls like a rock.
Is there a way to set up airmode on KISS the same way there is on Cleanflight.
In cleanflight you had to select airmode on an AUX and it would spin your motors at a minimum speed (at zero throttle - forever) no matter what.
On kiss it seems like it is always in airmode. Is that correct?
PsyBorg
Wake up! Time to fly!
If you have min command set to 1000 then according Final Glide (Chad) in the RR set up video yes Air mode is always on.
BE aware air mode does not and will not produce lift. It just sets a usable throttle range attached to pitch roll and yaw for steering not to power like throttle will.
