Need Help Running 19" LED TV on 3 cell LiPO
prion250
I am building a new ground station and need to know if my plan will work. (Before I burn something up)
I have a 19" LED TV that came with a power brick to turn AC into DC power (Like a laptop power cord). It has it's output listed as 12V 3A and the TV uses 24-30 watts. Instead of using the power brick I want to connect the TV to a 12V 3A UBEC and then a 3300mAh 3cell (11.1V) Lipo. Is this feasable or am I going to burn the TV up?:confused:
Links to the components:
TV = http://www.sceptre.com/Products/LEDTV/Specs/E195BV-SHD/E195BV-SHD MainPage.htm
UBEC = http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=35672
Battery = http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=20462
Nonamerc
Arman
why an ubec? A fully charged 3 cell lipo is 12.40V. You can always use a car battery if the TV uses allot of power.
