Mr. Gandalf, Thanks for your reply but unfortunately the manual says nothing about a factory reset. The manual is not much help as it tells you to use the button "GetUser" and that's what caused the problem. Once I did that and tried saving the parameters, I ended up with a file I temporarily called "save" that should have been the correct parameters but they were not. When I opened it, the settings were totally "whacked". I tried making changes to the incorrect settings, but one, channel 3 (Throttle) had no positive deflection of the associated bar in the T6 software. Only a minor deflection within the lower half of the bar. I checked end points and they were at 100% on all entries. I'll continue working with the program and hopefully, I'll be able to make the proper parameter changes. I'm hoping that someone made a file saving the original parameters that I can use with the configuration software.
