I just built a Simple Scout. I'm using a Motive-RC R8SB Rx a Jumper T12 Tx running a version of Open Tx. I tested everything before assembling, then I tested again after I installed each servo. Everything worked perfectly apart from the first problem 1 below. Finally, everything is installed and ready to fly until I accidentally connected the battery before I switched on the transmitter, which made the servos go full range backwards and forwards, though not the motor. I switched on the Tx, but problem 1 might have prevented a quick bind, so I unplugged the battery to prevent the ESC from over-heating.
Now I have problem 2: When I connect the battery with the Tx switched on, it seems to bind very quickly, so I have about 5 seconds of control, then all servos go full-range backwards and forwards a couple of times, then settle on full- range. By full range, I mean starting on 90 deg to the servo, then going right round to about 20 deg past in-line with the servo. They stop there with the ESC over-heating.
Problem 1 happened throughout the build: I bound the Rx in the normal way, and it worked like expected. If I disconnect the power for a few minutes, then reconnect, it re-binds straight away; however, if I disconnect and leave it for half an hour or more, then reconnect, it won't rebind automatically. The only way to get it to rebind is to activate the bind on the Tx (bind flashing), then, after a few seconds, the Rx binds without pressing the bind button on the Rx. Automatic bind is ticked on my Tx. Is there something disabling it? Is that what happens if you don't have it ticked?
Anyone got any ideas what I can do to get it working properly.
