Hello,
first of all, I hope this is the right sub-forum. Second, I need advices for my Quadcopter. I built it pretty clueless a year ago from an instrictable, this are the specs:
My Problem is now that the bearings of a few of the motors are bad, ratteling very bad, and I think one of the shafts is slightly bent (its a bit harder to turn and vibrates quite bad). Als I lost the E-Clip of one of the Motors, which I will reorder in the coming days. In my opinion the motors all vibrate stronger than which is good, but I don't know if its its normal or not.
My question now is if it's better to buy new bearings and maybe replace the one motor with the bent shaft or just buy "Good Brand" motors for christams (for Example T-Motor for about 35€).
I hope someone has a few constructive Ideas.
- Hobbyking X580 Glass Fiber Quadcopter Frame
- NTM Prop Drive 28-30S 800KV with Prop mounting stuff
- Afro ESC 30Amp
- KK2.1.5 Multi-rotor LCD Flight Control Board
- SLS 3600maH 30-60C 3S LiPo
- 12x4.5 Props
