Peter Savage
Hello people of the internet,
I am in need of a little bit of help, (feel free to skip intro) Let me explain my problem and hopefully someone with lot more knowledge than myself will be able to help me out or show me a way. So I bought the multi-rotor a while back but had to wait for the controller to arrive and for me to finish uni for me to play with my new toys, With uni finished I expected to be up in the air in no time.... Thus I was wrong! Connected it to my controller (turnigy 9x) fiddled with settings, (further down full list) calibrated the motors, all that jazz! Tied it to a wooden pallet so that if the unlikely happened and it took off I wouldn't loose it somewhere over Wales...... Point two I was being optimistic, armed the motors stood back for spectacular show of power and..... got about 25-30% max power and it not even to shuffle around on the pallet. In my despair I took to YouTube to find the answer and came back with naf all so looking from help from people who know the hobby inside out and upside down like you guys!
So just as side note:
Motors are spinning correct ways
Props are one the right way
I have noticed that the throttle still isn't changing the speed of the motors at all from about 5% throttle the motors spin up to about 25-30% and will remain spinning at the speed regardless of the throttle if i however yaw,rudder etc the speed changes in the direction i'm telling it as if it was flying, the motors also change direction if I lean it to try simulate wind and it tries to level its self out again. (all of these tests are the same with and without the props)
Can send video if needed to help understand
Right important stuff:
Multi Rotor setup
Hardware:
For the full list Click here >https://docs.google.com/document/d/1CG4cm21a1ql2Ld_7hApdIK1x6veqhIFkVDg5Y80XSt4/edit?usp=sharing
Many thanks
Peter
Multi Rotor setup
Hardware:
- 800MM HEXACOPTER frame
- 8x RCTIMER 5010 530 KV MOTORS
- 8x GRAUPNER 14 INCH PROPS
- 8x 45 AMP OPTO ESCS
- Aurdocopter v2.8 (APM V 2.8)
- NEO 7 GPS
- TURNIGY RECEVIER 2.4GHz 9X8C v2
- FLOUREON® 11.1V 5500mAh 3S 35C Lipo Battery
Many thanks
Peter
