brettp2004
Hey guys. I just received my fatshark goggles with the immersion RC tx and I'm having a problem. I wired the harness to fit on my gopro adapter. I plugged everything in and got a great picture for about 30 seconds, then it starts getting fuzzy and goes out. I've tried it with a 2S and a 3S battery, and also with the circular polarized and the linear antennas. I know my gopro adapter works fine because it works with my other FPV setup. I'm thinking that maybe the system is overheating and shutting down? The battery also plugs into the filtered balance lead adapter so the issue could be there. Another thought I had is that on my other FPV wire harness the gopro and TX have a common ground, since there is a filtered lead adapter I can't connect the grounds, I assume they are connected within the TX. Any help is greatly appreciated.
