I do have a full size BN Versa Wing, haven't flown it in a bit though. I enjoyed flying it so much, but its a little big to transport, that's why I decided to try the 70%. I have flown the full size into many things, ground, trees, my truck, a handicap port-a-potty (unoccupied) and probably many other things, and it still flies! I do plan to rebuild it also, the blunt nose is blunt both horizontally and vertically currently...oops. I even built a small bomb bay that I attached to the bottom of the Versa.
The 70% with the vertical fins flies almost identical to the full scale. With the first 70% I built I ran the 6x4.5 props a bunch and it flies FAST! But I also found that that was pretty much destroying the motor. I have some 5x3s on hand already so that is what I have been flying with, and they work fine but no where near as fast. Last night I got an 8 minute flight at full throttle with 1300mAh 3S battery and the 5x3 prop. I plan to buy some 5x4 and 5x4.5 to try out as soon as they are back in stock.
Here is one video from last night, I was trying to do low level passes between the trees. In the end I was looking down at my xmitter, i believe looking at trim inputs, when a gust pushed the mini versa down and with the wind. By the time I realized it I could't save it, but even though it skimmed the paved walking path going pretty quick and then flipped over, it was still fine and flew one short flight after this. Only damage was the prop was destroyed (first one on the mini versa) and the tape on the nose got a little scuffed.
