New Electric flat 4--20 HORSEPOWER!!!
Tim Hoyer
Watch This!!!!!
This is the biggest one we've built. 4 Turnigy 6364 SK motors, 4 Turnigy Sentillion HV ESC's, and 8, that's right 8, Turnigy 6S 6000mah NanoTech Lipos. Were close to 20 HP with this one and it's going in a massive Ultimate Biplane with an 8' wing.
CHELLIE
That is Soooo neet :D I like it :) How are all the motors tied to the main shaft ? Worm drive ? Keep up the great work, Chellie
colorex
Rotor Riot!
WOOOOO Awesome! Is this what Doc used in the time machine to get up to 88 miles per hour?
Tim Hoyer
Watch This!!!!!
A common shaft runs the full lengthwith a bearing at each end attached to a gear. Carrier gears are attached to each motor instead of useing the prop shaft. When you bolt down the motor it aligns with the gears and meshes together!!
JoeyG
Thats epic, build more! would it scale well building a flat six for smaller motors? look forward to seeing your progress. Nice one!
J.
Daniel Kezar
Ultimate Cheap Skate
that is a BEAST!!!!:eek::applause::applause:
