New Here! Starting Project: Why Not?
Hey everyone! I'm Aaron, and I'm starting an ambitious project called Project: Why Not?
My long-term goal is to design and build an original RC aircraft capable of attempting the Boom Supersonic Prize. I'm starting with limited experience and resources, so I've got a lot to learn before I get anywhere near that goal.
The eventual aircraft concept is called GRIM — Garage Research in Mach. It's an experimental aircraft concept with a pretty ambitious goal: finding out whether a garage-built project can reach the sound barrier.
The plan is to start by learning to build and fly, develop my skills in flight systems and instrumentation, and progressively work toward more advanced aircraft. I'll be documenting the journey publicly, including the builds, experiments, mistakes, and costs along the way.
For now, I'm focused on building a solid foundation rather than jumping straight into the deep end.
I'd love to hear from people with experience in the hobby!
If you were starting from scratch with this long-term goal, what would you learn or build first? Are there particular beginner aircraft, skills, or mistakes you'd recommend focusing on?
Looking forward to learning from everyone!
— Aaron
Project: Why Not? — One person. Ridiculous challenges. Real attempts.
Welcome to the forum! Looking forward to watching your progress. I have a fondness for the tech side of things as my title / Description notate. Hit us all up. We have a great variety of skillsets here covering the hobby and beyond.
Cheers!
Bricks
Welcome first thing is learn to fly and looking at your ambitions better learn very very well how to fly. Especially as it sounds like you will be doing a lot of maiden flights while designing your ultimate goal.
Sounds like a fun project! You'll definitely want to improve your flying skills before even building the plane. I've flown 150-160mph planes, and that alone took some nerve and quick reaction times. 700mph is gonna be a completely new story. I recommend building a FT tiny trainer if it's your first time flying (or mini explorer). Then once you have that one down, I'd move to the FT Arrow, then from there probably my Vortex/Radjet. Then just improve power plant till you hit 150 mph. (improving planes and power as skills grow) But after that, there isn't much advice I can give, other than maybe watch the videos from Mach Initiative on youtube, they're also trying to break the sound barrier.
Yeah, by the time you get into the Hundreds, let alone the sound barrier, a Flight controller, FPV, telemetry, Long range gear, and possibly a tracker are all going to be needed. (mmmm. GEEK stuff!)
— Aaron
Sounds like a cool project!! Good idea starting out with a trainer👍👍 For your first plane I'd recommend the FT simple scout since it only take a few sheets of DTFB (Dollar Tree Foam board) and there are free planes here on the forum that you can just print off on a regular office printer! After you get good with that I'd move to some sort of wing like the FT arrow since that is a bit faster and will get you used to hand launching, once you get good with that, move to something like the FT goblin to get used to launching a wing with a heavier wing loading, and then when you want to get your first taste of speed build @Mr Man's radjet! It only takes 2 sheets of DTFB, is pretty easy to build and can do over 150mph with a 3536 1800kv motor! (I have personally hit 158mph with it!)
Once you get there I'd take a look at flight controllers (aka FC's), the are basically a little computer board with gyro's and such inside that you put into your plane and then you can program in features like self leveling, auto launch and will even allow you to log the flight data such as speed, wing movement, max current ect onto an SD card! Like I said though, I'd wait on one of these until you are good at flying LOS (Line of site) because it can take a good amount of tuning sometimes to get it to fly nice and smoothly and you want to be bale to have the skills ot correct it if it does something unexpected.
Once you are comfortable with this, I'd try to make you next goal something that can do 300-350mph. At this point you will start encountering the programs you will face at 700mph, but be still going slower so if something does go wrong its not as dangerous as something going faster😂 (still insanely fast!!)
On a side note, you should join our speed channel that we do every year!! (Should be somewhere around April to May this coming year! That'll give you some time to get some practice in👍👍)
Oh, here are links to the plans of the simple scout and @Mr Man's Radjet👍
Simple Scout: https://goo.gl/39apYU
Mr Man's Radjet: https://forum.flitetest.com/index.php?resources/foamboard-radjet.515/
A whole bunch of other plans!!
Thanks, Mr Man! I really appreciate the advice, especially coming from someone who's actually flown in the 150–160 mph range. That's some serious speed! 😂
I'm definitely planning to build up my flying skills before trying to push the limits. The Tiny Trainer or Mini Explorer sounds like a good starting point, followed by a progression toward faster wings. I'll check out Mach Initiative, too!
On the technical side, I'm hoping to use my 3D printers and repurpose components from an old DJI F550 Flame Wheel for my first 3D-printed fixed-wing aircraft. Alongside that, I want to develop a reusable Flight Core built around a Pixhawk 6C, with GPS, telemetry, onboard logging, and a Beyond Robotix Special Dual Sensor Air Data Module Mini L100D using DroneCAN.
The idea is to build up the flight-control and measurement capabilities as I progress through different airframes, rather than starting from scratch every time. Eventually, I want to be able to compare onboard flight data against independent measurements as the speeds increase.
I know the jump from 150 mph to the transonic region is a whole different challenge, so there's a lot to learn before GRIM gets anywhere near that point. For now, one aircraft and one skill at a time!
Thanks again for taking the time to share your experience. I'll definitely be following your work!
Haha, absolutely! 😂 The nerdy systems side is one of the parts I'm most excited about.
I'm planning a reusable Flight Core built around a Pixhawk 6C, with GPS, telemetry, onboard logging, and the Beyond Robotix Special Dual Sensor Air Data Module Mini L100D using DroneCAN.
I've also got 3D printers and an old DJI F550 Flame Wheel to source components for my first 3D-printed fixed-wing aircraft. The goal is to build up my flying skills, airframes, and instrumentation together as I work toward GRIM.
Definitely learning to fly first, though! No point building an elaborate electronics package if I can't keep the plane in the air. 🤣
Thanks! I really appreciate the detailed progression you laid out. The Simple Scout into the Arrow, Goblin, and eventually the Radjet sounds like a great way to build skills without rushing things. And 158 mph is seriously impressive! 😂
I've got 3D printers and an old DJI F550 Flame Wheel I'm planning to repurpose for components for my first 3D-printed fixed-wing aircraft. I'm also planning a reusable Flight Core built around a Pixhawk 6C, with GPS, telemetry, and the Beyond Robotix dual-sensor air-data system, so I can develop the instrumentation as I progress through different airframes.
I'll definitely check out the free plans here and look into the speed channel! Having some experience under my belt before joining in sounds like a good goal.
For those who've built faster planes, what's the biggest thing you wish you'd learned before moving beyond trainer aircraft? Flying skills, building techniques, power systems, or something else?
Thanks again for the advice!
I'd saying I wish I'd not learned on a gyro, since getting off it took a while and I feel like it teaches bad habits like not getting your CG (Center of Gravity) right, and not using proper landing techniques. Another tip is to fly a bit higher up, since it gives you more time to react if something goes wrong when learning👍
Nice!! That's some pretty capable stuff👍👍
One thing I probably should clarify about the Flight Core: I'm intentionally aiming for more capability than the first aircraft strictly needs.
The idea is to build a reusable system that can follow the project from the early aircraft through progressively faster designs and eventually GRIM, rather than replacing the entire electronics architecture every time the requirements change.
That's why I'm looking at the Pixhawk 6C, dual CAN buses, onboard logging, GPS, telemetry, power monitoring, and the Beyond Robotix Special Dual Sensor Air Data Module Mini L100D from the beginning. I want to learn how to integrate sensors, collect flight data, and cross-check measurements on relatively simple aircraft, so the experience and infrastructure are already there when testing becomes more demanding.
Part of the reason is the Boom Supersonic Prize's measurement requirements. The rules call for onboard air-data measurements to establish Mach number, with reciprocal-heading GPS ground-speed measurements used to corroborate the result and account for wind. The aircraft must demonstrate that it exceeded Mach 1 after accounting for measurement uncertainty.
That means I don't just want to build something that flies fast. I want to develop the ability to measure what it's actually doing and understand how reliable those measurements are. I know the initial Flight Core won't be sufficient by itself to verify a supersonic attempt; independent instrumentation, calibration, and validation will be a separate development effort.
Obviously, I won't need every feature on every airframe, and I'll add equipment as appropriate. The goal is to build a solid, modular foundation once and carry the hardware and lessons forward instead of constantly reinventing the wheel.
For those who've built multiple aircraft with flight controllers, would you design one capable Flight Core to grow with the project, or keep each aircraft's electronics as simple as possible and develop the system later? I'm curious what has worked best in practice.
Usually I just add in a FC if it looks like I'm going to need it, otherwise I just fly plain old manual😂😂 (Because each aircraft is different, it always needs different programing so it can be a pain having to constantly swap it...though my FC costs $80+ so I can't just buy another one every time I need a FC in one of my planes😂)
That's a fair point! I know the goal is lofty, and the cost is going to grow exponentially as I get into higher speeds. My thinking is that if I build more capability into the Flight Core from the start, I can minimize how much electronics I have to repurchase as I progress. Hopefully that saves some money in the long run… at least until I inevitably crash and burn, which I'm fully expecting to happen at some point. I'm under no illusion that crashes aren't part of the learning process.
Yeah, usually the first flight is a little "unstable"😂 Just stick with it and you will get it!👍👍
I tend to OVER engineer my builds. I prefer Ardupilot over the other options. I have.also have an F550 which I have flown FPV on 6S. People are always "hey I had one of those". Then I do a full throttle punchout and they are like "WOAH! Mine wouldn't do that!".
This was on 3S a L-o-n-g time ago.
I haven't flown much over 100mph, but have a few things capable of 200+ that are nearly done.
