My recommendation is to tune with the auto level turned off. Also, make sure to but something to isolate the KK2 board from vibration. The foam packaging that the board came in is fine. Use some double sided tape to hold it to the foam and to hold the foam to the quad. Don't bolt the board directly to the quad or the vibrations will cause problems.
With P too low, your quad will probably feel sluggish, slow to respond, but not oscillate. The best way I can describe it is that it's like you're flying a wet noodle. With the P too high, it will be very responsive, but oscillate as it is over correcting.
Tuning P for pitch/roll:
- Set your I values to 0.
- Set your P pretty low and test.
- If it doesn't do fast oscillations, raise P up by 5 or 10 and try again.
- Keep raising until you get the fast oscillations.
- Lower back down by 5 or so
With I too low, the quad will tend to center itself or drift from the angle you tell it go. With I too high, will produce slow oscillations. With I tuned to where it should be, it should hold the pitch/roll angle when you center the stick and not drift and won't oscillate.
Tuning I pitch/roll:
- make sure auto level is off
- test fly, pitch the quad forward and center the stick. the quad should keep that angle and keep flying.
- if the quad levels out, you need to increase pitch I
- keep increasing and doing this until the quad holds it angle after centering the stick
- if the quad starts oscillating (it will be a slower oscillation than when P is too high), lower it back down some
- do the same thing but fly side to side to find your roll I
After you get it tuned like this, then fly it around a bit to see how you like it. Write down your settings and then play around with them to see how it changes the flying. Depending on what you are doing with the quad, you might want it to be less responsive and oscillate less to make smooth video. If you are racing, you might want your P gains higher to make it more responsive but have some vibration as a trade off.
After everything is flying right, then mess with the auto level gains. Doing the autolevel last is good because your quad is already flying well, so you aren't fighting with other problems. If your quad is wobbling without the autolevel, you are going to have problems because the autolevel will be trying to counter act it and they will fight each other.
