cdfigueredo
Hello, guys.
I've been looking for a model for flying in the wind for a while. Many have advised me to fly wings like the FT versa wing. But I'm really excited about the idea of building a DLG. I was really worried about the fact that I couldn't find carbon rods here to build the fuselage, so I decided to look for a solution. And that's when I found the DLG flying wings.
I found this wing: HobbyKing Bird Plane DLG and it seemed easy to reproduce using EPP. I decided to make the plans using the same wing shape but scaling it up to 1m wingspan because my servos are bigger and my electronics heavier.
The smaller battery i have is a 3S 800mAh 73g. I know it is not the ideal but it is what i have. Also i don;t have any BEC so i am planing to use a 18A ESC. The whole electronic weights 122g plus the RX 6.5g will be 128.5g just for the electronics.
I cut the wings yesterday. It is only 55g. but i need to add two wood spars for each wing so it would be a necessary weight added.
I have a lot of doubts, so I would appreciate all the help you can give me. It's my first glider and I want it to go as well as possible.
