Bat bone, tricopter setup. I have 8x4.5 and Turnigy 2730-1300 motors. Mounting props on with the insert, the shaft is not long enough for the collet mount on top.
The last pic (bottom right) is the prop on with no insert. The prop goes all the way down, does not fit tight. Collet mount can be attached, but the prop is loose (not right).
I tried the prop adapter (rubber ring), that didn't seem to help - prop were still loose - wiggled when spun up.
Can someone assist me with the right way to get these mounted?
Thanks
JD
Thanks
JD
