Bacon8tor
Hello all since finding flite test about a month ago I have built 3 designs the FT Delta, FT Mini Scout, FT Spitfire. all successful built but had to buy electronics. after buying a tx/rx it was time to place an order. Here is what i set out to get
- battery
- esc
- motor
- propellers
-charger
- some more servos
This was my first time i spent countless hours on Hobbyking trying to figure out what I needed, with some help from BanditJacksRC I found a motor ,esc, battery, and charger. . Let me take a step back. I had contemplated buying the electronics from FliteTest, I had purchased the spitfire kit, but Since i needed other things like a charger i wanted to only pay shipping once other wise my budget was cut so short that i couldnt afford to buy the electronics pack fromt FT and the charger from hobbyking. So these are the items I bought and what i missed and newbs should watch out for,
NTM Motor - this motor comes with the plugs already soldered on(not sure if this is normal) , but does not come with accessories No Motor Mount or connector from prop, this is my own fault it does clearly say no accessories but i missed it,
ESC esc comes with no connectors, this does not say this on the product description. also not sure if this is normal for esc's to come with out plugs to solder onto.
battery no complaints here, its a battery, lol
so what i learned is make sure you have the adapters or accessories needed when you order something. Unfortunately i learned this the hard way. So that is why I wanted to share this, now waiting to get paid again to get the other stuff i need, thought I'd at least be able to center the servos on the planes but cant do that now until i can get connections for esc to battery and motor.
- battery
- esc
- motor
- propellers
-charger
- some more servos
