NEXT LEVEL P-40 Group Build
PoorManRC
So.... Where I'm at now!
Finishing and MESSING UP the Access Hatch!! 😲😜
BTW - BEST Tool I've used for cutting Foam Board so far!! πŸ˜ŽπŸ‘πŸ‘
Thanks to my Wife's friend, a RN. πŸ˜‰
LATER!!
More to come!
PoorManRC
WHILE I figure out HOW I'm going to get more Brown WP Foam....
I went back to the Vstab!
I now know WHY I've been told to NOT use Black Adam's RediBoard!!!
And the fact that the Tail Feathers are DOUBLED, adds quite a lot of strength - without adding a lot of WEIGHT!
.... Like putting .085" Steel Wire in the Vstab of my Tubby Cubby!! πŸ˜²πŸ˜–
The Hangar
Fly harder!
Thanks! I really appreciate that! 😊
Good Idea, that I will pass to others....
I will NEVER be able to afford any System like that, as cool and effective as it is.
I no longer expect anyone to understand just how Poor we actually are. πŸ’”πŸ˜ž
We're just trying to get through each day.
This Hobby is literally SAVING my Sanity!! Thanks to FliteTest - a guy who can no longer afford FAST FOOD - can enjoy one of the World's most Expensive Hobbies!! πŸ‘
Of course, without the help from my friends, I couldn't even do this.
The Idea exchanges in this Forum are PRICELESS!
Sorry you are so poor. I kinda understand, cause I’m pretty poor myself, but not to the level you are... but Flitetest is really a lifesaver for all of us isn’t it? The only plane I’ve bought, not built is the hobbyzone champ because none of the ft planes were able to fly in the crazy small spaces I sometimes fly in. Other than that, dtfb and my power packs to the rescue!
PoorManRC
@BATTLEAXE Thank you! I really do like doubling the Tail Feathers. For the first time, I didn't have to reinforce the Elevator!! πŸ‘‹πŸ‘‹πŸ‘‹ That alone is lighter than adding wood or Wire (my only 2 options) .
Using Gorilla Glue instead of Hot Glue, saves more weight than I imagined!! 😲😎 I only used Hot Glue, on the LE of the Hstab.
You just NEED the patience to WAIT hours for a part to set up, instead of minutes!! 😲
AND in Arizona, with 48-53 degree C Summers - Hot Glue isn't always the best solution....
@The Hangar as long as FliteTest doesn't change (Although their SBKs HAVE gone UP quite a bit), the PO Folks will hopefully be okay.
...... If Bix wanted to GIVE me a P-47 SBK, I wouldn't say no! πŸ˜‚
PoorManRC
More....
Yeah, it added WEIGHT! πŸ˜– But it's at least over the CoG!!
THAT was a very hard lesson for me... Telling myself that this isn't a Showpiece. It just had to look GOOD!! πŸ˜‰
THIS ONE STEP took way TOO long - even for ME!! πŸ˜œπŸ˜‚πŸ˜†
BATTLEAXE
HOLY CRAP, what an awesome 2 minutes of flight, the maiden was a huge success till I had a LOS over some trees. Got the plane back, found it on the ground. It was fast and sensitive to the controls, the most maneuverable plane I have flown yet. I will post video tonight or tomorrow but this is the end result.
A lot of work went into this one and taught me a lot about how the speed wing flies, definitely making more speed wing planes.
Got all set up with more FB and gonna build a stretched out Scout with a speed wing set low on the fuse to look like a vintage Schneider Trophy float racer but with a Rat Rod vibe. I will post this build on my Scout thread.
PoorManRC
Sorry about the outcome Bud.... 😞
But at least it seems like you REALLY enjoyed the short Maiden!! 😎 Plus you've learned and gained valuable experience.
The Schneider Trophy Scout sounds SWEET! πŸ‘πŸ‘
I still have another unbuilt Scout... As always, I'll be taking notes!
BATTLEAXE
Here it is, it flew so fast and true, barely any trim. I was shaking the whole time. I kept throttling back to see if it would drop but it held like it was on tracks, till the LOS. Even the drone cam couldn't keep up.
You can get an idea of how fast it was.
I thought the FT-22 was quick, this P-40 was twice as heavy and made a mockery of the 22. Speed wings all the way, feels like the first time. You can tell by how much space I was taking up.
PoorManRC
..... I MAY not even use this (MIGHT sculpt an Intake Scoop out of the little bit of Blue Extruded Foam that I've got left).
But I thought I would "play" with an idea I've had rattling around!! πŸ˜‹
NONE of the parts had any Fold Diagrams.......
So I put my own rudimentary drawings on them, so I wouldn't forget! πŸ˜œπŸ˜†
I know!! This stuff REALLY expands! 😎😲
It really seemed like a pointless, empty thing!!
To me anyway. (I'm probably wrong lol) πŸ˜‹
Filling it with the Spray Foam made it a SOLID Piece, appears that it will add a fair degree of crash protection....
And the Foam Fill added SO LITTLE weight - I couldn't even get it to register on my Scale!! I'm CERTAIN that it weighs something.
Since it Keys into the front of the Wing....
If I also fill the area from the T.E. of the Wing, to the front of the Spar - it COULD feasibly provide significant "Lawn Dart" Crash protection!!! πŸ˜πŸ˜ŽπŸ‘πŸ‘
IF it doesn't help, it didn't add enough extra weight, to make any difference! πŸ˜‰
The LOS issue really worries me! But being one of the FEW things that seems to be beyond even the most Experienced Flyers...
I'm TRYING not to stress about it! πŸ˜‰
PoorManRC
Did some repair/reinforcement/functionality Mods to the double Foam Tail Feathers....
I may end up ripping all of the Black Paper... The adhesion to the Foam is HORRIBLE! πŸ˜–
Had a slight issue with the Hstab....
I'm fixing this, even though it's nothing but aesthetic...
.... As I've learned, the Paper - especially the Maker Brown Foam Paper.
This was just TOO ugly!! Plus every time I sanded the Black Paper, it usually shredded and tore.
So HERE'S how I fixed that.
This will also clean up the messy Hinge Line some...
Not using Hot Glue, really helps keep the Weight down - especially in the Rear, where it's critical!!
BATTLEAXE
Definitely looks a lot better now, nice recovery
