nnMIG 3 Swappable - design, build, and review log
abah
First learn to fly with MIG3
I found some flight videos of abah flying his nnMiG 3 on youtube!
Thank you for putting my video link here.
Sorry the videotape only a short duration. because my friend can not be recorded properly.
I myself is someone who is very new in the world of aeromodelling, just as happy with a model created by master nnMIG3 Nerdnic I tried to make it, the result is pretty good for me as a beginner.
Because in my town no one sells foam board / depron like you're using, so I can only use materials from the former box I get the grapes in a fruit market and then I process into 5 mm thick, this material is heavier than Foam Board .
But this will still be the best experience for me and I will continue to be creative by using makeshift materials. Thank you for providing a place for me in this forum host Nerdnic.
jayz 84
Abah. You have done some very impressive detailing work on your mig3, it looks awsome and its great that you can fine alternative materials to make your build. Nice job man
so I put some right into the pod. since I saw reference to trying it. seems like a good idea. my question is, what if I put to much. would kinda side effects would I see flying?
jayz 84
Are you talking about adding right thrust?
AkimboGlueGuns
Biplane Guy
You might notice a slight right turn tendency. If you WAY overdo it you might get a really weird torque roll, but if you just enough it'll reduce the left turn tendency of the plane.
jayz 84
Start with two washers behind both right side motor mounts ( motor facing you view) and if you have a problem with it wanting to pull up during full throttle add two washers under the top left mount too. If you continue to have the issue just add another washer , to adjust the angle more but i cant see you going past 3 washers if so then theres a different issue. You can also build the thrust angle into the pod like in the might minis pod. They have down and right thrust built in. Thinking about it now you might beable to print out a mighty minis pod at a 145% and that should give you a full size pod dimensions. Now just trace the scaled up mini pod angles on to the stock fullsize power pod plans and that should give you a perfect down to right thrust angle built into you pod. ( just a idea)..... now to much right thrust will result in a pull to the right under high power
hmm I didn't put any down in it like the minis have, but it seemed pretty good at staying level under power last time I flew it. just looking at it after I built it and was like hmm that's a lot. it actually looks about the same as the mighty mini pod has. which might be over kill on a plane that wasn't much worse than a stock ft Mustang for tq roll as it was but I was running a smaller prop then.
iwlf
I didn't build any right thrust into mine, but I did add a rudder. Doesn't seem to need any down thrust. Put in some right thrust if you don't have rudder control, should help a lot.
nerdnic
nerdnic.com
I've not added any right thrust to mine yet but I will be soon. ??? the amount you added is on the higher end but I think it will still work.
nerdnic
nerdnic.com
Great work on the paint job! I'm very impressed that you got such a nice finish using fruit boxes, that's some real dedication :)
nerdnic
nerdnic.com
So I can't share all the details just yet but.. I may or may not be working with FT on an episode involving the nnMiG 3.
iwlf
Flew several batteries through the MiG3 yesterday. The other guys have their warbirds and complain "I can't keep up!" with my MiG3! I'm really enjoying this one, nerdnic! Zoooooom!
nerdnic
nerdnic.com
And that friends is what we call a cliffhanger
nice dude! I knew that would happen eventually :)
I always hoped!
Hmmmmmmmmm, Josh Nerdnic. Has a ring to it doesn't it.
I wanna do the intro. 'Hi this is nerdnic, welcome to FliteTest.' Think they'll let me?
Nice! Are you running the Tacon now?
