That's awesome, Nic!
My own nnMiG-3 is all but ready to fly. There's a very short list of things to do before the maiden, which I expect to happen sometime in the next week or two.
Many Russian planes of WWII would have written on them "ЗА РОДИНУ", "Za Rodinu", a battle cry that translates "for the motherland" (also sometimes called the fatherland).
Mine says "ЗА КУЗЮ", "Za Koozya", after a Russian online gaming friend of mine who goes by that name. He had been after me since I started building models to make a MiG-3, so when you released your plans last fall, I knew I would be making one soon.
It has more detail than any foamboard model I've ever made. The edges of all control surfaces are nicely edged in Beacon Foam Finish. A co-worker helped create the exhaust stacks on his 3D printer. I made a control yoke from some scrap aluminum control rod and kite string. The guns on top of the fuselage are bamboo skewers (sanded obliquely for a nice taper). The pilot was conscripted from a Parkzone Wildcat cockpit. The list goes on and on.
She has the 'Flite Test style' flat-bottom wing. I found it necessary to taper the spar for the wing to go together correctly. It is quite thin... at the transition to the undercambered section it is about three thicknesses of foam. A spruce spar spans the flat center section of the wing.
I also made the wing removable. It is attached with some liteply at the front, and a single bolt at the rear that threads into a nylon locknut secured in the fuselage with some wood and bamboo.
I added a cooling vent on the bottom, and doubled up the number one former at the nose, so I could remove much of the foam to allow airflow. It's basically an open arch that leads to a NACA inlet above the power pod, as Josh did with the FT Mustang. My Spitfire "AN-T" died last year due to an ESC failure almost certainly caused by insufficient airflow. I don't want a repeat of that failure.
Oh, and of course I added a movable rudder, because hammerheads.
Anyways... enough words. Here's a photo.
I hope she lives long enough to attend Flite Fest.
