I maidened my MiG on Saturday. It didn't go as well as I had hoped, LOL.
The launch was OK, it turned left quite a bit due to motor torque, but it immediately straightened out.
Then I got a quick feel for how sensitive the elevator was, and began to gain altitude so I could start trimming her out.
Things were going OK until I started that left turn. It was a little sluggish going in, so I kept feeding in more stick and then suddenly the inside wing tip-stalled and she rolled inverted. I paused a moment to recover some airspeed and when I tried to roll it back right-side-up it did a complete roll and I very nearly lost orientation. It seemed hyper-responsive and overcontrolling.
At this point, I'm just hoping to level it out before it hits the ground. I manage to mostly do so, and it didn't nose in.
It came down RH wingtip first. The wing attachment points failed, and the wing came loose. The upper wing skin got a single crease in it, but the structure stayed intact. Then the fuselage hit, damaging the RH nose bottom and briefly twisting the power pod enough to loosen one of the locating pins for the firewall. Lastly the fuselage bounced back on the LH tip of the horizontal stabilizer, causing about an inch of crinkled foam, mostly on the bottom side.
Relatively minor damage, considering how badly it could have ended. It's almost 100% fixed already. The power pod got slightly crunched and now has a small amount of right and down thrust. I'm going to leave it that way, rather than replace it. It's plenty sturdy... it's just had it's angle changed a bit. The motor and prop came out unscathed.
I'm thinking that there were three major factors in the crash. 1) excessive control throw, 2) excessive expo, and 3) dumb thumbs.
My theory is that I had the aileron throws set so badly and with so much travel that they actually caused tip stalling.
What's an acceptable amount of travel for the various control surfaces?
