No roll control
flyer1275
In betaflight under the receiver tab, you can check stick operation I did this and have no roll control, no matter what map I choose
I built this Qaud and have been trying to get it set up for , let’s just ay a very long time I was in the process of setting up gps When I figure something out and move on Icheck back to make sure something hasn’t changed which it does especially in ports I managed to get my receiver on ,but if I change anything else it blanks all but the factory presets Not very user friendly Anyway is my radio bad or have I changed something inadvertantly? Has anybody run across this?
flyer1275
What I found was I had no movement on aileron
No matter the map. I just deleted the model
and started again, if you remember to turn on radio before qaud. there no problem except I have no throttle Betaflight and the radio show there is movement but there is not
