Hello out there in the blue beyond!
I'm a noob to RC and the like. I scratch built a Mighty Tiny Trainer and picked up a used transmitter. I had help setting up my Apprentice to the transmitter by a generous veteran. . I now need to set up the DX7 for The Tiny trainer 3 channel and the Tiny Trainer 4 channel ( So I'll have 2 different wings one with dihedral one with ailerons, as per FliteTest plans.
I've gotten as far as naming two new models on the transmitter, then......I realized , I don't know what I'm doing. The DX7 manual is good but I'm too "new" at this to know what to program. What will I need to put into the transmitter for a simple 3 channel airplane. I'll also need to know what to put in for the 4 channel model.
I'm using a DSM2 receiver and a compatible ESC (basic, with no programing required for ESC), with 5g servos. I have had success binding the electronics so I know that works, but will have to rebind once I have set up the correct parameters. This is where my problem comes to light.....I don't know what I'm doing!
I most-likely went through the bind process with a "old Model" the former transmitter owner had used.
My Model 1 is the Apprentice and is still in memory. The "new" Tiny trainer models are model 3 for 3 channel and model 4 for 4 channel. I have not entered any parameters for each model yet (waiting for someone with experience to comment about what info to put in). I know that I'll have some switches to assign and some other basics to attend to in setting up such as rates for rudder, elevator, motor curve, and ailerons. The manual will help with that task, maybe.
Question***********************************************************************************
****Is there a basic approach I should use for a simple 3 channel and a basic 4 channel? Are there basic parameters I should know about? ***
Searching the forum, I have not found that general information.
Any help will be appreciated,
Thanks in advance,
jb
Thanks in advance,
jb
