sumone
I'm still fairly green when it comes to this stuff & have never scratch built before
I recently bought a few cheap items from china
i got this setup.
1400KV Outrunner Brushless Motor + 30A ESC 1045 Propeller
A2212 1400kv Motor Specification:
KV: 1400
Max Efficiency: 80%
Max Efficiency Current: 4-10A (>75%)
Current Capacity: 12A/ 60s
No Load Current: 0.5A
Number of Cells: 2-3 Li-Poly
Motor Size: 27.5x38mm/1.08''x1.5''
Shaft Diameter: 3.17mm/0.12''
30A Brushless ESC Specification:
BEC: 1A / 5V (Linear mode).
Output: Continuous 30A, Burst 40A up to 10 seconds.
Input Voltage: 2-3 cells lithium battery or 5-9 cells NiCd/NIMh battery.
Max Speed: 210,000rpm for 2 Poles BLM, 70,000rpm for 6 poles BLM, 35,000rpm for 12 poles BLM. (BLM: BrushLess Motor)
and a few cheap rx's
I banged together this rough lil plane .
but i'm not sure what size battery would suit with the included prop.
I also bought a cheap 2200KV Motor Outrunner Brushless.
would it be better ? and if so what size prop and battery?
Thanks in advance.
i got this setup.
KV: 1400
Max Efficiency: 80%
Thanks in advance.
