So far high speed settings haven't made a difference, I've tried with the high needle settings from all the way in to about 2 turns out. It does make a difference in running at higher speeds, but everything at the low end just ends in the engine dying.
There are new gaskets on both sides of the carb mounting block and I've verified the gaskets line up with the pulse hole.
This carb has no choke, but I did try putting my finger over the carb opening (partially covered, half-covered, mostly covered). When the video was shot yesterday I had it running at a mid-low speed for a few minutes, plenty of time for it to warm up.
The clunk is a pretty good sized piece attached with new Viton gas line. The tank was about 2/3 full, and I even pulled the line from the carb to let the gas line drain a bit to make sure there were no bubbles in the line.
