Hey there all,
After a lot of help from members here (through highjacking others' threads) I've been able to get my new Versacopter in the air! It hovers somewhat stably and I can direct it in various directions the way it is supposed to move given my input. In other words, I've tested the controls and it pivots when I use the "rudder", tilts up and down when I use "elevator", strafes when I use "ailerons", and goes up and down based on my throttle position. I'm flying in horizon mode, but I've popped it in to what I believe is "acro" mode enough to see what that is.
Here's a terribly photographed glamour shot of what I call the ConnQuad 1.0 (based on my last name).
As you can see I have the camera-holder attachment sitting there on the front and have my old-ass gopro strapped down with crude velcro straps. This leads me to my first question.
How should I attach my GoPro to this mount?
My current solution is not super stable, I can wiggle it around by hand. While I haven't seen any wobble in the first video I recorded, I basically just hovered. I'm assuming that looseness will be no good if I expect to whip this thing around turns at high speed. I have concerns about it just being exposed as well. While I have the big complete plastic enclosure that I could use to hold the camera, at this point I'm assuming that that is not worth the weight. The enclosure weighs more than the camera, if I remember correctly.
You can also see from the picture that I have a 2200 3 cell battery on there. So far I haven't purchased any batteries exclusively for the vc, but I have about half a dozen in this size range that I've used for ft versa fixed wings, storch, and my newish ft explorer. So far they seem okay, but that leads me to my second question:
What sort of batteries should I be using?
For now I'm just going to use these 3 cell ones I have, but what would be the ideal 3 cell? Or 4 cell, when I get to that?
On to the next question...
Can someone just tell me what I should set my PIDs to? I have no idea how to dive into that.
I have the powerpack that flitetest defaults to when you purchase the versacopter kit, I believe E? 12 amp escs, Naze 32 rev6, running without oneshot125 (can't seem to get that to work, seems like I have to reflash my escs themselves, don't want to get into that yet although I do have an arduino board)....
Oh, and at least one more question...
Can you tell me what I need in order to utilize the FPV camera I already have?
I obviously want to get FPV going on this thing. For now the GoPro is just for recording. I'll try to use that directly for FPV in the future, but I thought I would like to try to use the only video transmitter system I currently have. It looks like this:
I got it when the FPV Vapor with goggles was on sale at Horizon. Came with Fat Shark goggles. I realize that the range is pretty garbage but I was hoping I could use this for a bit while working out how to upgrade. What do I need to do to power this on my versa? The versa build videos mention patching other systems to the PDB in passing, but I have no idea where to start with that. This camera successfully "just plugs in" to the Vapor and my Sport Cub S, both tiny planes that use those 1s thumb batteries. Can I just use one of those somehow?
One last question, I promise.
How should I upgrade?
1)If I want to get a better FPV system going, what should I get? Can I go any further with my Teleporter headset by only upgrading the transmitter side of the deal, or does any improvement require an upgrade on both sides?
2) Any other upgrades you think I should do? Things you learned with this kit, that I could implement now? I have some spare money this month to spend on this thing and I want to enjoy it this summer.
Thanks in advance for any advice and thanks for reading.
