Old charger with new battery?
I'm planning on making my first scratch build and was wondering if I can use a charger that came with the Hobbyzone Super Cub S With SAFE made for this battery , with a battery from the ft store. Would the charger still work if I use a new battery? I can't remember what charger it is (specs and stuff) but if I go looking I can find it if you want (I had to quickly write this post before I left to go somewhere)
ElectriSean
Eternal Student
The discharge leads are different on the 2 batteries. Many chargers have leads that connect to the charger with banana connectors. If yours is such, you can buy just the leads and it will work fine.
#3
The charger uses the white Charing (I think) connector (4 pin connector thing) of the battery for charging, so will it still work with the new battery as long as I charge it with the white connector?
FlyingMonkey
Stuck in Sunny FL
Admin
#4
You should be able to, but I'd buy a new charger.
The ones with those Hobbyzone kits are really the cheapest possible chargers, and you have no way of telling what it's actually doing to your battery.
I look for a display that will show you the charge status of each cell. Support for both the balance plugs and for the discharge plug. Also a way to power it from house power. That said, you want to make sure to charge your batteries in some sort of fireproof system.
https://www.youtube.com/watch?v=gobFcNzGG9I
https://www.youtube.com/watch?v=K6hGvXxFTFA
Some examples of chargers...
https://store.flitetest.com/imax-b6ac-pro-battery-charger/
https://store.flitetest.com/x100-ac-dc-100w-touch-screen-charger/
https://hobbyking.com/en_us/accuell-s60-ac-charger-us-plug.html
#5
Can any of them work with TX-30 connectors? I can't really find where it says it
EDIT: or should I just buy a EC3 to TX-30 adapter?
