Well, got my new heat shrink today, so won't be using silicone tape other than for field repairs from now on. Thankfully weather stayed a little cooler (barely over 100f) the past few days so the heat shrink didn't arrive pre-shrunk
Over lunch did a few bench tests on the hex trying to see if I could figure out which motor was running hot...and what I found was perplexing. I'm starting to wonder if maybe something happened to my FCB in that mild crash at FF.
Just hand holding with minimal throttle I'm seeing what at first looked like a possible reset. All the ESC's cut out (blue lights off then back on) but nothing was running hot yet. Did a few more tests and found I could get it to do it by giving the hex a quick tip while hand holding it, the more aggressively I tipped it the more likely it was things would freak out.
Then something really odd happened. Gave it a really strong tip to the right. All 3 motors/ESC's on the right and the left rear motor/ESC suddenly cut out. Lights off (and didn't come back on) while the two front left did keep going.
So now I'm starting to think it's either a FCB issue or something between the FCB and the ESC's. The hot ESC/motor I detected last weekend may have just been a symptom of whatever is going on. (Note, this testing is being done in acro mode to minimize the number of sensors involved.)
There is a new firmware build out for the Brain, but given I've been flying on the current build for 3.5 months with no issues I don't believe it's likely to be the firmware.
Taking the arms off for travel did include two screws that both hold the arms and the FCB stand-offs. Which has me wondering if maybe I overtightened those causing the FCB mount screws to tighten as well transmitting more vibrations to the FCB. Seems unlikely but possible.
It could be I damaged the gyro in the MPU-9250 - but again seems unlikely as it was a very mild crash and I've had MPU's survive MUCH harder crashes in the past.
I suppose it could be damage to signal wires on the ESC's - but they look good. One did look a bit beat up the other day but I replaced it. Or it could be damage to the PDB since the signals run through there...I'll have to do some major disassembly to inspect that.
Very odd situation indeed. But at lest I seem to be closing in on potential causes.
Just very odd that two different builds with very little in common both developed similar issues. Would be nice if my LC meter from China got here quicker so I could take a closer look at the motors...though the DYS with notably different resistances on the quad sure seems like the issue there.
